intake question LT1 verses TPI
Old Mar 12, 2007 | 10:15 AM
chevytuned's Avatar
Can any one tell me witch intake is better the TPI or LT1 I have both and not shore witch one to use on my supercharged 94 camaro thanks.
Old Mar 12, 2007 | 08:53 PM
96capricemgr's Avatar
Well putting a TPI intake on an LT1 would be no small task, a lot of differences to account for.
Most people love to hate the LT1 intake but reality is it WORKS very well for a huge range of applications.
Old Mar 12, 2007 | 09:52 PM
chevytuned's Avatar
Thanks for the reply, The motor that I am going to put in the car is out of my truck with the TPI allready on it and the motor that is in the car has the LT1 thats why I wanted to know witch one would be best to use I dont know much about the LT1 but I have been playing with the TPI for a while.
Old Mar 12, 2007 | 09:58 PM
If I understand your question, you are putting a Gen 1 SBC from some truck into a 94 Camaro. Then you are going to supercharge it. The LT1 intake would need to be converted to work with the Gen 1 SBC heads. There's an outfit that does it, including addition of the hole for the distributor and the water connections, because its a popular swap into the 3rd Gen F-Bodys. I've seen the LTx intake support 1,125HP on a blown 383ci LT1, so it would appear to be a good choice. The long runners of the TPI intake probably are not going to offer any benefit in blower setup, probably more of a hinderance.
Old Mar 13, 2007 | 08:15 AM
chevytuned's Avatar
Thanks for your reply Fred I looked at your car very nice. The motor I built already has the newer heads that will work with the intake I converted the TPI intake to work with that motor I only put about 50 miles on it when I decided it would be best in a car so I got the camaro to put it in. I am also running a th400 trans with a manual valve body. Is there any thing I should know about installing it in this car /speed cable,trans suport, ect./ ?
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
4586
Dec 6, 2014 05:20 PM
Lederman1976
Nov 30, 2014 05:21 AM
Jul 4, 2005 05:00 PM
