Anti-freeze not circulating
Old Mar 12, 2007 | 06:54 PM
flames2ashes9762's Avatar
94' TransAm. OK so i just changed my coolant temp sensor and after filling it back up with antiz-freeze, it won't circulate now. both hoses coming from the radiator are cold and i have no heat. Is this just a matter of getting the system primed? The anti-freeze in the radiator is boiling and the motor is over-heating. help?
Old Mar 12, 2007 | 06:55 PM
30696bird's Avatar
Did you bleed the air out?
Old Mar 12, 2007 | 06:57 PM
30696bird's Avatar
If not here is a picture of the bleeder screws.....
Old Mar 12, 2007 | 06:58 PM
Z95m6's Avatar
You probably need to bleed the air out. There are 2 bleeder screws one in the thermostat housing and one in a radiator hose near the alternator. I always just start the car up and crack open the screws and wait for coolant to come out. Then close the screw really quick.
Old Mar 12, 2007 | 09:06 PM
moparman's Avatar
Check the radiator and see if it's full. Be sure it's cold.
Old Mar 12, 2007 | 10:09 PM
Blacksmith's Avatar
Thumbs up 1 more thing
you might wanna check your water pump activity as well. i had a similar problem with my 93 z28. couldn't really tell by looking at the weep hole. i found out by accident when jacking the car up and noticed a coolant run down the front of the block.
Old Mar 13, 2007 | 06:11 AM
Ok i will try that thanks guys, but i've never done this before (bleed air out of the coolant system) You just crack those screws open while the car is running? Anti-freeze isnt gonna come out of them? Thanks, your guys help is much appreciated!
Old Mar 13, 2007 | 07:03 AM
moparman's Avatar
Check the radiator first. Refill if necessary. You want a steady flow of coolant to come out of the bleeders. No bubbling sound of air escaping. Check the radiator everyday until it stays full.
Old Mar 13, 2007 | 08:36 AM
94 CAMRO Z28's Avatar
Yes, make sure the system is cold first, then top off the radiator. Although there wont be a ton of fluid coming from the bleeds, you may want to stuff a rag or two under/around the bleeds to catch the fluid. If this doesn't do it maybe a stuck thermostat? Water pump gone south?
Aaron
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Jul 10, 2015 02:23 PM
MrDude_1
Nov 2, 2004 03:24 PM
Finchinater
Oct 3, 2003 01:22 AM
