Intake oil leak, a question....
Old Jul 11, 2003 | 09:46 PM
craigffb's Avatar
I'm going to do this tomorrow. In the manual and some people even on here have said to pull the fuel rail. I've looked around under the hood, and I really can see what pulling the rail is going to do besides take more time. If you don‘t pull the fuel rail can you not get the intake off or something???
Old Jul 11, 2003 | 09:57 PM
Re: Intake oil leak, a question....
I would pull the whole intake as a unit. All you need to do is disconnect the fuel rails from the supply line with a tool.
Old Jul 11, 2003 | 10:02 PM
craigffb's Avatar
Re: Re: Intake oil leak, a question....
That's what I was thinking. I may pull the injectors off once the intake is out because the kit I got has new gaskets/o rings, but I can't see why you would need to pull the rail before the intake came off.
Old Jul 12, 2003 | 07:16 PM
craigffb's Avatar
Got it done. Took me about 5 hours. I did have to pull the fuel rail. The back two bolts would have ben hard to get at with the torque wrench. I just hope it wasn't the rear main that was leaking. I'm pretty sure it was the intake beacuse there was oil on the back of the head on the passenger side.
Old Jul 12, 2003 | 07:43 PM
mehoffz24's Avatar
WOULD THIS WORK. instead of using just RTV or supplied silicone, do you guys think it would work if you made a gasket from neoprene for the china walls and still used the RTV with the new gasket, would this be the answer to all leaks from the walls.
what do ya think?
Old Jul 12, 2003 | 07:46 PM
craigffb's Avatar
what do ya think?
I don't know. I did wrap the EGR tube with heat tape and used Ultra Copper RTV. Hopefully it will hold up for a while. The reason it leaks (a least what I've read) is because the heat from the EGR tube breaks down the RTV.
Old Jul 12, 2003 | 07:55 PM
what do ya think?
Earlier small blocks did have gaskets there and they always seemed to ooze out. The RTV will work fine if done correctly.
Old Jul 12, 2003 | 07:57 PM
mehoffz24's Avatar
ow long should the RTV set up before being out together
Old Jul 12, 2003 | 08:00 PM
craigffb's Avatar
Put the intake back on right after the RTV is put down. Bolt the intake down and tighten to specs (35 FTLBS), put everything back on and let the car sit for 24 hours before starting. Mines is sittig now.
Old Jul 12, 2003 | 08:03 PM
BKZ's Avatar
BKZ
If goign to use RTV use a center punch and make small dimples on the intake and top of the block...(not where the intake touches the heads you'll be useing a gasket their). This is what the GM garages around here do to keep the RTV from sliding out once it sets up.
Old Jul 12, 2003 | 08:05 PM
craigffb's Avatar
I hit mine with sand paper.
Old Jul 12, 2003 | 08:52 PM
I did that to mine. Not the part in the circle.
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
