Please Help With AC Problem
Old Jul 12, 2003 | 08:39 PM
Brandon 95 Z28's Avatar
Angry Please Help With AC Problem
My AC hasnt been working right for a while now. I used to be able to get it to come out by hitting the dash right above the ac controls. It would periodically work then stop working. Now it has completely stopped working, it sounds like it is turning on and off, it just isnt blowing anything out the vents, hot cold, or defrost. I evacuated and then recharged the system today and that did nothing for it. Could it be the blower motor or compressor? Cause it seems to hold pressure, it just doesnt blow anything, and I am dying in this 115 degree heat, thanks
Brandon
Old Jul 12, 2003 | 08:55 PM
If you don't get the fan blowing out anywhere, then you have a problem with the fan or fan circuitry. The blower fan is under the RH side of the dash.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
