Intake manifold leaking?
Old Jul 26, 2009 | 12:48 PM
spike30th's Avatar
Hey just wondering will a intake manifold leak would cause smoking out the exhaust at wot?I just noticed the front of my motor is wet. It appears to be oil splattered all over everything and there was a little oil pooling up on top of the timing covering right beneath the manifold. And I pulled the PVC valve and it had a little oil in it.
Old Jul 26, 2009 | 12:55 PM
Have you checked the crankcase for excessive blowby? That will cause smoking at high RPM, and pressure in the crankcase can blow oil past the seals on the front and rear of the engine. The fact that you have oil in the PCV valve may indicate a high loading to the valve, entraining oil droplets from under the bottom of the intake manifold (or someone left the baffle pan off the bottom of the intake manifold).
At idle, pull the oil fill cap off and feel for puffs of air blowing out the fill cap or a 'chuffing' noise.
Old Jul 26, 2009 | 01:11 PM
spike30th's Avatar
I don't have the stock valve covers. The valve covers I have I use a breather for the oil cap which leaks like a champ. But I will pull the breather and see what happens. Thanks
Old Jul 26, 2009 | 01:19 PM
The breather may be "leaking like a champ" because there is excess blowby/crankcase pressure. Might be time for a compression and leakdown check.
Old Jul 26, 2009 | 01:57 PM
spike30th's Avatar
This motor only has about 1500 miles on it. I guessing the rings never seated.Well I guess I will have leakdown and compression test done and go from there.
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
