Intake leak damaging clutch?
Old Jul 3, 2003 | 01:39 PM
Transcam96's Avatar
I just read that one person said that his intake leak killed his clutch. I just replaced my clutch and my intake is leaking a tiny bit. Can that intake leak actually do something bad to the clutch? I thought that there was a cover around the clutch to protect it.
Thanks for you answers,
Jacques.
Old Jul 3, 2003 | 01:40 PM
Hyperspeed97z28's Avatar
You best get that leak fixed ASAP my friend, the oil leaks through the bell housing.... and in slight long terms WILL KILL THAT NEW CLUTCH... Trust me....
Old Jul 3, 2003 | 02:53 PM
nateh's Avatar
If you leave it, oil will get on your disk (with the friction material) and will ruin it. Your clutch will start to chatter. The only cure then is a new disk. I just replaced a disk that had plenty of wear left, but was unusable from the leak.
Old Jul 3, 2003 | 02:54 PM
FuryZ28's Avatar
I had an intake leak for two years and oil never touched my clutch.
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Jan 30, 2015 11:08 PM
rjc1629
Jan 27, 2015 10:46 AM
artic94
Jan 17, 2015 11:19 AM
