Intake leak damaging clutch?
I just read that one person said that his intake leak killed his clutch. I just replaced my clutch and my intake is leaking a tiny bit. Can that intake leak actually do something bad to the clutch? I thought that there was a cover around the clutch to protect it.
Thanks for you answers,
Jacques.
Jacques.
If you leave it, oil will get on your disk (with the friction material) and will ruin it. Your clutch will start to chatter. The only cure then is a new disk. I just replaced a disk that had plenty of wear left, but was unusable from the leak.
stockssn2o
May 25, 2015 08:54 AM
