Intake Gaskets, again...
Old Jun 3, 2008 | 07:55 AM
OutsiderIROC-Z's Avatar
I am looking for an intake gasket set that does NOT rely on just a bead of silicone on the front and back gasket surfaces. I am pretty sure that I have a leaking intake manifold gasket, the gaskets were newly installed back in March.
The car is running rough and is smoking from the back of the engine.... I read the other topic on here about the leak on the back of the motor, but his symptoms of leaking from the oil pressure sender do not match mine.
BTW, car is a 95 Z28.
Thanks in advance.
Old Jun 3, 2008 | 08:02 AM
The RTV in front and back IS the best way. Gaskets squish out. That's the way they used to seal them and that is why they changed to the RTV. As with anything, if the work was not done correctly, it may end up leaking again.
Old Jun 3, 2008 | 05:13 PM
Some people have "dimpled" the surfaces of the manifold and block to increase the "grip". Do not use "silicone".... its possible for air leaking past them to pull vapor into the intake via the PCV valve, and silicone contaminates the O2 sensors. Use the correct, sensor-safe sealant.
Slide the intake on with dowels in two of the bolt holes to make sure it seats "squarely". Be sure to torque the intake in two steps. Be sure to let it cure for 24-hours before you start the engine. Be sure to check the intake bolt torque a week or two after the install.
Old Jun 3, 2008 | 05:17 PM
joeSS97's Avatar
RTV is the best way. It must be applied properly. Clean surfaces,nice bead and ithe mani put on straight down. Then allowed to cure. The area by the oil sender is the thinnest area to seal. I messed it up once and I am sure many others have...
Old Jun 3, 2008 | 05:22 PM
TobyZ28's Avatar
This is really a 2 person job too I think 1 person could do it but given how important it is to get a good seal without wrecking the RTV bead.... Its much easier to lay it down with 2 people.
As injuneer said, use some dowel to line it up (We used chopsticks broken in half on the furthest and opposite nearest bolt hole, pencils work too ).
Let the bead of RTV sit for a little while to skin over so its not all runny. Then place the intake on it, then let it cure for a day. Be sure not to use OLD RTV!!! Get a new bottle if your unsure of how old your RTV is, if its a couple of years old it may never set. (I had to do the job twice )
Old Jun 3, 2008 | 05:23 PM
TobyZ28's Avatar
Just read this part of your post - what color is the smoke? It sounds like you may have a blown headgasket...
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
thenewkid
Nov 27, 2014 09:41 AM
