installing rail mount fuel pres gauge, need thread sealant?
i'm installing a fuel pressure gauge on my lt1 fuel rail where the schrader valve is. I didn't know if i needed to apply any teflon tape or special thread sealant or anything.
thanks
thanks
i'm also a fan of the paste, it can get a little gooey at times though. I also didn't know if teflon junk could stand up to fuel or not.
thanks
The Schrader valve is a -4AN fitting. You should not use any sealant on the conical surfaces of the fitting, and no sealant is necessary or recommended on the -AN threads. If you are screwing together some sort of external NPT thread fittings to adapt to the Schrader, teflon tape or paste sealant is used on the NPT threads.
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
