installing a hot cam
Old Jul 26, 2004 | 06:58 PM
dabez1's Avatar
My friend just got a low milage lt1 from a 97 impala. He wants to put in a Hot cam but he wants to know if he can use the stock springs, rockers and so on.
Old Jul 26, 2004 | 08:31 PM
dabez1's Avatar
Re: installing a hot cam
ttt
Old Jul 26, 2004 | 08:34 PM
Camaro_Maniac63's Avatar
You can use stock rockers, however, than you will only get .492" lift instead of the .525" with the stock rocker arms. You will also need to replace the springs, even if you stay with the stock rocker arms.
Old Jul 26, 2004 | 10:09 PM
dabez1's Avatar
so hot cam, Rockerts, and springs. No timing belt ot anyother things
Old Jul 27, 2004 | 08:49 AM
It is always a good idea to upgrade your timing chain too with a cam swap.
Old Jul 27, 2004 | 09:52 AM
GREGG 97Z's Avatar
Tell your friend to just buy the hotcam kit, it comes with the correct springs for the cam, 1.6 roller rocker arms, valve caps, shims, locks. The hotcam by itself with the stock rocker arms wont be as strong as it would with the 1.6 roller rockers. I would install at least a new stock timing chain or upgrade to a stronger one and install new gaskets of course.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
Queens94z28
Dec 20, 2014 09:11 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
