installing headers on lt1
Old Apr 11, 2007 | 01:06 PM
  #16
mzgp5x's Avatar
Shorties allow more engine and road clearance, and, a small underdrive pulley allows the engine to rev quicker. Longtubes are great, but, the remaining exhaust is also important. ie... high flow cats, cat-back system, and electric cutout to enhance flow. (97SS 383 - D1)
Old Apr 11, 2007 | 01:07 PM
  #17
TobyZ28's Avatar
Mechanix Gloves, a breaker bar, a 2nd set of hands to help
Old Apr 11, 2007 | 01:39 PM
  #18
CamaroRacing12's Avatar
def mechanix gloves lol and some more pb blaster
Old Apr 11, 2007 | 02:50 PM
  #19
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Is PB Blaster superior to other penetrating oils?
Old Apr 11, 2007 | 03:02 PM
  #20
150&6K's Avatar
One thing that I found useful is a short wrench for the number 8 bolt and I would also suggest some stage 8 locking header bolts. Do you have duel cats or the single? I have the slp duel cat shorties (should have gone with lt’s but didn’t have the money) and I also had to get a new exhaust manifold flange gasket for the drivers side cat because it started to leak.
Old Apr 11, 2007 | 06:42 PM
  #21
kartracer0000's Avatar
i just have one cat on my car. it is a 93 t/a
Old Apr 11, 2007 | 06:52 PM
  #22
zx1216's Avatar
I doubt u will have to jack the motor up at all with shorties, i didn't have to touch that with my long tube pacesetters, i did have the front end 3 feet in the air though
Old Apr 11, 2007 | 06:55 PM
  #23
i was going to put the car off the ground on jackstands all the way around the car to have plenty of room underneath the car to work. I have sprayed PB blaster on everything i can see pertaining to the manifolds. is there going to be enough room to get a torque wrench to tighten all the bolts down the same?
Old Apr 11, 2007 | 07:05 PM
  #24
zx1216's Avatar
that sounds good, idk about the torque wrench, the only stuff i really use a torque wrench for is stuff dealing with the internals of the motor or the intake manifold, everything else if pretty much the german method, goot n tight, lol
Old Apr 11, 2007 | 07:06 PM
  #25
2000GTP's Avatar
Good luck fitting a torque wrench in there. Just use a ratchet or wrench.
Old Apr 11, 2007 | 07:34 PM
  #26
reamo04's Avatar
just take ur time
it took me and a friend 12 hours to do headers and make duals, that was including an hour lunch break, so, id say 5-6 hours for headers, an hour or so for plug wires
Since you're doing headers, i would go to thunderracing.com, and buy the OTVC kit there. U have to cut the wires to length, but it will save many burnt wires in the future
Old Apr 11, 2007 | 07:36 PM
  #27
2000GTP's Avatar
Originally Posted by reamo04
just take ur time
He's going to do shorties though, so the stock wires should work out for him.
Old Apr 11, 2007 | 09:18 PM
  #28
What kind of plugs and wires would yall suggest? i am just going to keep doing bolt ons to the motor.
Old Apr 11, 2007 | 10:42 PM
  #29
96 mikez28's Avatar
+ 1 lol
Old Apr 12, 2007 | 12:26 PM
  #30
2000GTP's Avatar
NGK plugs and Taylor wires are my favorite choices.
