installing a harmonic balancer....help
Old Jun 21, 2006 | 06:43 AM
ghost stripes's Avatar
i have to reinstall my balancer and i figured to put it on just put it on and tightened down the center bolt ....well thats not working i am using a impact gun very strong .and still nothing .....any suggestions? thanks
Old Jun 21, 2006 | 06:53 AM
sssalah's Avatar
Re: installing a harmonic balancer....help
Are you taking about the hub that holds the damper? This is an interferance fit part that needs to be pulled on the crank snout somehow. Using the crank bolt to pull the hub is just going to damage the threads in the crank, remeber these are fine threads.
Old Jun 21, 2006 | 07:02 AM
its the center bolt on the dampner usually you slide it on and tightened it down ....its one bolt not 3
Old Jun 21, 2006 | 08:10 AM
contraststriker's Avatar
what year? Need to know if it's press-fit or keyed.
Old Jun 21, 2006 | 09:27 AM
If its an LT1, its press fit, with no key.
Old Jun 21, 2006 | 10:43 AM
Oh yeah you're right, my bad. Thunder Racing sells a keyed balancer hub for all LT1s, I should have noticed.
Old Jun 21, 2006 | 12:26 PM
got it on and it went on with the bolt tightened ....thanks
Old Jun 21, 2006 | 02:28 PM
OBE1 95Z28's Avatar
As stated above, you're lucky you didn't strip the threads In the future use a threaded rod. Thread the rod until it bottoms out in the crank snout. "Pull" the hub onto the crank snout by using a nut and washers (or a flat bearing) to tighten (pull) the hub into place. This will prevent stressing the threads in the crank.
Nov 18, 2023 07:21 PM
eanhl2004
Apr 4, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Mar 7, 2015 09:21 AM
cyteone
Feb 7, 2015 06:04 PM
