installing CSR pump, what to do?
Old Aug 19, 2005 | 03:20 PM
snakethis69's Avatar
it seems like my new CSR pump is not mating correctly to the housing, it seems as though its rubbing on the inside of the housing, why? should i drind away some of the material? i already did the ears but dont see anything about this? should i grind the fins a bit or the inside of the hoyusing, and repeat i did the ears
Old Aug 19, 2005 | 03:30 PM
ZMAN Z28's Avatar
Re: installing CSR pump, what to do?
Did you replace your electric CSR with a new CSR? Anyways if I understand correctly, the new pump hits on the factory housing? I don't see why you shouldn't be able to do some clearancing inside the factory housing. I'd get some more opinions though?
ZMAN
Old Aug 19, 2005 | 03:40 PM
no i am converting from stock to CSR, yes the fins hit the inside of the housing, i dont know if that needs to be smooth to circulate water or if i can just grind the blades a teeny bit
Old Aug 19, 2005 | 04:35 PM
calfirebird's Avatar
Me and my buddy have one and we didnt have any issues inside the water pump, You did take the bearing out on the inside Right? That is all i can think of.
Take a look at kens page and make sure you did everything for csrs directions suck.
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Old Aug 19, 2005 | 04:45 PM
yup, i just grinded the fins a bit and it is fine now
HectorM52
Jun 23, 2016 08:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
ANDYZ28
Dec 29, 2014 09:13 PM
thenewkid
Nov 27, 2014 09:41 AM
