I checked the fuel press. and it is ok, so I pulled the rail up and had someone turn the car over and the fuel injectors were not injecting. What could be the problem?
Did you check the fuses for the injectors? Did you check to see if you have +12V on the colored wire at each injector harness connector with the key in the "on" position.
