Installed the LTCC setup today!! WOW!!
Old Aug 23, 2003 | 09:06 PM
REPO's Avatar
Well, I got the LTCC setup installed today. In a word, WOW!!!!
I think I have been chasing my tail trying to get this car to idle better. I spent alot of time drilling the hole larger & larger in my BBK throttle body to get the IAC counts down. Well now after the install, it is idling at 1100 RPM!!! It idles better cold, has much criper throttle response, and just feels way better on the low end. I havn't had my foot in it yet, so I'm not sure about top end.
I am hitting the track on Sept. 6th to I will see if it actually made any difference in how it runs up high.
But so far, this is one of the best mods I have done to help this car run with the stroker. (383, Xtreme 236/242 cam)
Again, I recommend this mod!! I love my car again!!
WWWWWEeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old Aug 23, 2003 | 10:22 PM
Josh'95Z28conv's Avatar
Cool. I want to do that too. Sounds great man
Old Aug 23, 2003 | 10:37 PM
94GrayV6's Avatar
I wish I could afford one, my ignition system has given me nothing but problems.
Old Aug 23, 2003 | 10:57 PM
HardcoreRM125's Avatar
Someone want to educate me as too what that stands for ? ( LTCC )
Old Aug 23, 2003 | 11:07 PM
Info
Old Aug 24, 2003 | 07:05 AM
zuluman13's Avatar
Will the optispark still break if water gets to it.
Old Aug 24, 2003 | 07:26 AM
jkipp84's Avatar
The opti should survive water ok, it's the coolant that will do them in quickly.
Repo, do you have an pic's of the LTCC installed? It sounds like a pretty good system, but I'm not too keen on that pile of coils on top of the manifold look. I'm asking because I spent a good while cleaning/painting/polishing mine. I don't really want to hide it now.
Old Aug 24, 2003 | 08:25 AM
REPO's Avatar
I'll try and get some pics today. Email me if you want pics and I will email them to you.
Old Aug 24, 2003 | 09:28 AM
ltlhomer's Avatar
You can mount the coils wherever you want (although the closer the better probably for less resistance) but I'm sure a few extra feet isn't going to hurt you. I even saw one guy from this site mount them under his car by the radiator.
Old Aug 24, 2003 | 09:33 AM
Originally posted by ltlhomer
........I even saw one guy from this site mount them under his car by the radiator.
You mean like this?
Old Aug 24, 2003 | 10:00 AM
KGRESOCK's Avatar
I second your WOW.
I've been running the LTCC for 3 weeks now and the
car has never run better.
Smoother idle, and it revs so much QUICKER.
Not to mention the outstanding customer service.
Old Aug 24, 2003 | 01:42 PM
Josh-'04 GTO's Avatar
Originally posted by Injuneer
You mean like this?
That is a cool setup Fred. Any problems driving through puddles, etc. (Not that your car sees many!) Water/moisure would be my only worry about putting them there.
Old Aug 24, 2003 | 04:47 PM
96 WS6's Avatar
So whats involved in getting the ltcc setup to work? I know you need 8 coils and you use the optical section of the opti as a crank position sensor correct? Is there some other componenet you need to make it work?
Would this or a dynaspark be a better choice???
Old Aug 24, 2003 | 05:01 PM
REPO's Avatar
You can buy a dynaspark that is specifically made for the LTCC setup. It just has the optical sensor in it. No rotor and connections for wires.
Old Aug 24, 2003 | 09:05 PM
showtime89's Avatar
What did your version cost you?
