INJ big enogh for NOS????
Old Jun 30, 2013 | 02:54 AM
race u 2's Avatar
Ok been out of the game for awhile. just pulled the cover of the car and blowed the dust off. I'm thinking of playing around with my NOS but not sure if my INJ are big enough. The last data log I had the inj duty cycle was hitting 73. So can i shoot say 125 shot to it or 50 any opinions. I will start out low at 50 and go up but have heared some people talk about locking up inj so should i just go get a new setof inj?
__________________
Old Jun 30, 2013 | 03:57 AM
slick1hunting's Avatar
I would go with a wet shot and then your injectors wont need upgraded nor your tune changed. I ran 125 without retarding the timing but a 100 is safer and 75 even better yet with no retard. Keep in mind if your going to run a nitrous plug or not too. With the wet shot its not a big deal to swap in bigger jets for special occations but I cant say with a dry shot.
Posted from Camaroz28.com App for Android
Old Jun 30, 2013 | 07:54 AM
race u 2's Avatar
Re: INJ big enogh for NOS????
Thanks for the reply but I already have the dry set up on the car and yes i will change plugs. But I just wanted to know if my duty cycle is getting to close to the limit with my current setup. The NOS was ran on the old engine but not my new one.
Old Jun 30, 2013 | 09:54 AM
Are you running the NOS 5176 LT1 dry kit? If so, that system boosts the fuel pressure when you spray, to increase the flow capacity of the injectors. If not, what dry system are you running?
Old Jun 30, 2013 | 10:06 AM
Since you already have this posted on the N2O Tech forum, this one will be closed down.
https://www.camaroz28.com/forums/n2o...nj-nos-874572/
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Sep 18, 2015 03:46 PM
canuck94z28
Aug 19, 2015 05:50 PM
NewsBot
Aug 3, 2015 02:40 PM
