incorrect firing order isnt my only problem help!
after correcting the firing order my car ran fine but the engine was wobbling from side to side bad until it warmed up. and it would almost die and then it would throttle back up and run fine for a couple of minutes to 10 or 15 minutes. anyone have any ideas? its a 96 engine and exhaust with 95 pcm and harness. no mods.
Re: incorrect firing order isnt my only problem help!
how long did you have a misfire, if it was over a long period of time, it is most likely a plugged cat problem. i had the same problem when i had two wires crossed. if that doesn't work...check egr.
grabbem88
Mar 18, 2015 01:25 PM
