opti crap
Old Aug 11, 2005 | 10:49 AM
runninfromthelaw's Avatar
opti crap
just a quick question has any one clean the insides of the opti to see if it would last longer or work better.
Mine has 120k on it and i just now started to have problems with it so if i cleaned it will it last for a few mounths till i get a delteq.
Old Aug 11, 2005 | 02:27 PM
hotazzz28's Avatar
Re: opti crap
What kind of symtoms are you getting to tell you its the opti?
Old Aug 11, 2005 | 04:43 PM
Re: opti crap
cruising speed studders
Old Aug 18, 2005 | 09:41 PM
hotazzz28's Avatar
Re: opti crap
I have the same problem, combined with my exchaust popping when I floor it. When/if I figure it out I'll fill you in. I've heard a few different things now so I've been thinkin I'll wait. If its the opti maybe it will crap out totally & then I'll know for sure.
Old Aug 18, 2005 | 09:48 PM
snakethis69's Avatar
Re: opti crap
my opti just crapped right before my cam install. i just cahnged it when i did it and all my problems are gone. i had hard starts and high RPM misses if anyone wanted to know some syptoms
FastZinTennessee's Avatar
Re: opti crap
I think if you remove it, take it apart and start trying to clean the inside of it you'll run more of a risk of the thing not working when you get it back together. I'd chance it hanging on for a few months until you are ready for the delteq. If it craps out you can have my old opti, it runs good except for not firing the #7 cylinder
Old Aug 29, 2005 | 01:56 PM
hotazzz28's Avatar
Re: opti crap
This may not apply to your situation, but I think I solved my problem by removing the hypertech programming & going back to stock. The car seems to idle better & the popping is gone. I am going to have GM check for any tripped codes before I reinstall the HPP2 programming.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
jayblev95
Sep 26, 2015 09:44 PM
tdigger9899
Sep 7, 2015 10:56 AM
asilomar244
Jul 12, 2015 05:53 AM
