Is it important for the spark plug ground and electorode to be parallel???
Old May 26, 2006 | 01:10 PM
96 WS6's Avatar
When gapping plugs, especially for me with a .032 gap, is it necessary to have the ground parallel to the surface of the electrode? When I gap the plugs it always turns out that the .032 gap is at the tip of the ground only because it's curved. Should I use pliers to straighten it out and regap it???
Old Jun 1, 2006 | 12:58 PM
rskrause's Avatar
Moderator
Re: Is it important for the spark plug ground and electorode to be parallel???
I doubt it makes any difference, but I have no empirical data to either confirm or refute this assumption.
Rich
Old Jun 1, 2006 | 02:02 PM
96 WS6's Avatar
I have about 20 different spark plug gapping tools, including a wide assortment of ring and blade feeler gauges. The problem is, that autolite 104s come with a .045 gap. The rule of thumb is to not change the gap either larger or smaller by more than .008"... I needed .032 and therein lay the problem. I managed to get it done by holding the ground strap in a bench vice with some VERY intricate maneuvering.
I'd think that if only a single edge of the end of the ground strap is the closest part to the electrode, you have significantly decreased the surface area from which the spark would jump as compared to if the surfaces were parallel. As with you Rich I have no clue as to whether or not it makes a difference, I just wanted the piece of mind to know that the plugs were not causing any unforseen problems.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
