Immediate TBB Help please!
Old Jan 29, 2004 | 03:55 PM
Tair's Avatar
I have NO idea how I'm supposed to reach the clamp on the left side of my '94 Z28. NO WAY IN HELL could I ever reach that left side clamp, even after disconnecting the IAT sensor. How did you guys reach it?
Old Jan 29, 2004 | 04:04 PM
DrewHMS97SS's Avatar
one of the better reasons to replace the crapy squeeze clamps with screw clamps. you are talking about the one on the left side (looking straight at the car), on the bottom, the coolent line?
if this is the one i have a tool that is great for squeeze clamps. it has a grip, when squeezed pushes a clamp together. the clamp and the grip are connected together buy what looks like a bicycle hand brake line. if you cant find one of these try taking the TB off and putting it in a better possition.
Old Jan 29, 2004 | 04:07 PM
Tair's Avatar
sorry, i meant how the hell do you get to the coolant line on the left (passenger) side.
Old Jan 29, 2004 | 04:13 PM
yeah. the tool described is what i used. if you cant find the tool, take the tb off the intake to get a better angle on the line.
Old Jan 29, 2004 | 04:20 PM
TraceZ's Avatar
Just pull off the TB... it is only 4 bolts! be carefull with the gasket.
Old Jan 29, 2004 | 04:25 PM
SCNGENNFTHGEN's Avatar
I have used a long 45 bend needle nose. It worked pretty good for me.
Old Jan 29, 2004 | 04:26 PM
I have used a 45 bend needle nose. It worked pretty good for me.
Old Jan 29, 2004 | 04:27 PM
My PC is acting funny, sorry bout the double post!
Old Jan 29, 2004 | 04:28 PM
Tair's Avatar
is the left-side coolant line the one that faces exactly downwards at the ground? in the diagram I have the coolant line appears to be facing more towards the front of the car than downwards. Even if I take the clamp off on the left side, I can't hold the coolant line from just dropping. I'm about to give up....tbb is the most difficult mod EVER! lol
Old Jan 29, 2004 | 04:45 PM
What did u mean, "can't hold it from dropping off"?
Old Jan 29, 2004 | 04:56 PM
all you do is pull the clamp off and remove the hose.
Old Jan 29, 2004 | 05:01 PM
Put a rag down so you don't spray the opti with coolant. I have heard of them getting wiped from getting wet!
Old Jan 29, 2004 | 08:18 PM
good point
Seabat
V6 Tech
Sep 11, 2009 11:07 PM
z2896
Dec 14, 2005 03:35 AM
black02z28
Aug 17, 2005 03:55 PM
Seabat
Sep 2, 2003 10:26 PM
dmaastr
9
Jul 1, 2002 02:22 PM
