I'm thinkin 396...
Old Mar 26, 2007 | 09:10 PM
95z28man's Avatar
I'm thinkin 396...
I think I've come to a conclusion on what I want my build up to consist of. I want a 396 LT1 block from Golen (this comes with crank, rods, pistons, freeze plugs installed). The only issue is what to do about heads/cam. I'm assuming that since this is an LT1 block, I can reuse my existing heads and send them in to be worked on, correct? I know of a few places of the top of my head, VRE, AI, Lloyd E. and I think ARP? Is there a certain choice that may have better options for a 396? I will also be looking for someone to do a custom cam for the setup. Any advice from you guys who have worked with anyone on 396? I recall someone posting about AI recently. Anyone else?
Old Mar 26, 2007 | 09:21 PM
Javier97Z28's Avatar
Moderator
What are your goals for the car?
A4 or M6
Do you care about track times?
Old Mar 26, 2007 | 09:41 PM
reamo04's Avatar
Personally, i will be doing a 396 LE3 car, was going to do a 383, but i can get a 396 shortblock for a mere $50 more.
Old Mar 26, 2007 | 10:03 PM
SS RRR's Avatar
I'm going with my LPE CNC LT4 heads that I bought 10 years ago on my current 396 project just to see what happens. I've been told by Jason Short and a few others after giving the specs they will work very well. We shall see...
Old Mar 27, 2007 | 01:08 PM
cmroSS97's Avatar
i have le2 heads they are def the limiting factor on my motor.I think you need a set of trickflow ported by Lloyd on any stroker motor if you want the hps. I already had the le2 heads so i threw em on but I want trickflows. 396 sure makes alot of torque though
Old Mar 27, 2007 | 05:46 PM
remaxracer45's Avatar
reama04 where are you getting your 396 and how much?
Old Mar 27, 2007 | 05:55 PM
reamo04's Avatar
from our vendor, victoryracingengines.com
3700 for the short block i believe.
They are also teaming up with AI, so u might ask them about that
Old Mar 27, 2007 | 08:53 PM
95z28man's Avatar
To answer some questions, my car is A4, and yes I'm looking for the best track time I can get (assuming I already had slicks and a new rear...which i don't yet)
Although I would like fast track times though, it also has to be somewhat of a daily driver. I will be working with some suspension items as well to try and maintain a good balance between drag times and streetability as well.
Hope that helps some, if you need anymore info, post up
Old Mar 27, 2007 | 09:27 PM
reamo04's Avatar
just like everyone will tell you - streetability is all in the tune.
What heads/cam are you looking at?
If you can give us more details on your setup, that would be great.
Old Mar 28, 2007 | 09:04 AM
95z28man's Avatar
I was planning on saving my old heads, sending them in somewhere to have them checked and tested (I believe almost anywhere will do that), and then have them replace all the springs, valves etc. and whatever else goes into getting more power out of them.
For the cam, I was just going to have someone make a custom cam for my application, I was looking at Lloyd Elliot for something like that.
ucantZme
Apr 4, 2003 08:06 PM
convertz
Middle Atlantic
15
Mar 21, 2003 11:01 PM
lrm95transam
Mar 21, 2003 05:24 PM
ThotYouKnew
Feb 17, 2003 01:52 AM
mook99TA
Nov 13, 2002 09:44 AM
