Price for Rebuild
Price for Rebuild
HPP in lewisville Texas is saying I have a bottom end knock. The motor has less than 5 miles on it and the company that built it is now out of business. I am on my own for the new rebuild. How much is a good price for them to remove the long block and get it rebuilt(hopefully rods and crank are intact) and put it all back together with my old forged i beams and new forged pistons?
Keep in mind i think minimal damage has been done to the internals and no serious machine work will be needed.
Just have them change out the bearings and check everything out. With 5 miles on it the rings and everything else should be brand new. I would imagine it not being more than $350 to assemble the short block, add bearings and some gaskets. You should be lucky that it didnt have serious damage.
That is a loaded question. No one can tell you how much when you don't really know what is wrong with the engine. You probably spun a bearing and if you can find someone who can tell you what the damage is without pulling the engine, good luck.
Mechs charge anywhere between 55/hr to 85/hr=- plus parts. Ask HPP what they charge per hour, but it won't make much difference if they have to pull the engine and take it apart.
I truely hope that it isn't serious, but $hit happens. I know.
Sergio
Jan 27, 2016 04:27 PM
