i'm getting knock retard!!!
Old Apr 2, 2003 | 02:33 PM
1994TransAm's Avatar
hi there,
i'm getting knock retard... and i dont like it.. ussally its a .3 to 3.5 range according to my scanmaster. i just finished my cam 700 miles ago... along with exhaust.
what can i do.... can bad plugs and a coil make knock? i have new wires...and they aren't burnt. i kinda have a crappy idle after 10 seconds or so with the brake on? can a dyno tune help me find this?
Old Apr 2, 2003 | 02:45 PM
teke184's Avatar
what kind of exhaust? i've heard of headers causing knock...
maybe try a lt4 km...
Old Apr 2, 2003 | 02:50 PM
First you need to determine whether it is picking up "true knock" or "false knock". True knock often arises from low octane fuel, excessive inlet air temp, excessive coolant temps, too much timing advance, oil contamination of the A/F mixture, excessive compression ratio, including carbon buildup effects. Put a tank of 100 octane unleaded in there and see if the problem persists. I've seen a "bad" tank of Sunoco 94 cause the levels of knock retard you are reporting, a problem quickly fixed with a fresh tank of fuel.
If the high octane fuel doesn't solve the problem, then you need to look at sources of false knock, and that can include any mechanical noises that would reach the tiny microphone that is the knock sensor.
Old Apr 2, 2003 | 02:55 PM
i have the KM and i'm using edelbrock shorties... the car is strong... but i'm worried. put in some octane booster (NOS) and it went away for a bit.. then i filled back up.
just incase... i purchased a short block on ebay. and i'm gonna rebuild that if anything happens to mine.
can plugs or ignition cuase KR... or is it just mechanical noises.
can bad tuning cause KR?
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
