ignition short or battery terminals??
Old Mar 6, 2012 | 04:27 PM
BmoreLT197's Avatar
ok guys i need some help i have a 97z the other day my car started struggling to start so got a jump and went to work thinking maybe i left something on...car did it again so i got the battery tested and it was ok alt and starter was as well... and even with a jump the car wouldnt start up now and i had to pop start it...now the car started to short out every time i try to turn the key to the start position and the dash will light back up when i reset the key position and then short over and over so i cant even attempt to start the car...help please!!
Old Mar 6, 2012 | 04:29 PM
Dave89IROC's Avatar
Clean the battery terminals, ground at the block and main starter terminal
Sent from my PC36100 using Tapatalk
Old Mar 6, 2012 | 06:41 PM
mrmint69's Avatar
Re: ignition short or battery terminals??
Seems like something in the starter or wiring. Almost like something arching or coming disconnected there. Check the positive and negative cables from the start to the end.
grabbem88
20
Dec 27, 2015 07:42 PM
nosliw
Apr 26, 2015 02:13 PM
eanhl2004
Apr 4, 2015 12:01 PM
nosliw
Feb 7, 2015 01:30 PM
Decromin
Aug 18, 2002 10:11 AM
