ignition problems
Old Nov 30, 2006 | 09:52 AM
kmnracer10's Avatar
ignition problems
have any of your cars done this? when i turned on my car everything is fine and then ill turn it off and the ignition doesnt want to come out of the ACC poisition so i can't take my key out and then when i finally wiggle the key out the ignition doesnt budge at all its almost as if its frozen any sugeestions? thanks
Old Nov 30, 2006 | 09:59 AM
bingo's Avatar
Sounds like you need a new lock cylinder.
Old Nov 30, 2006 | 11:02 AM
Sweetred95ta's Avatar
It would be nice to know some information on your car (signature), but for now, I'm going to assume it's an A4 and this may be a fix.
http://shbox.com/trans/park_lock.html
Old Nov 30, 2006 | 02:13 PM
kastraelie's Avatar
Before you start taking things apart try this first, its worked for me for the exact same problem three times now.
Put your car in neutral, and WHILE turning the steering wheel to the right push the car backwards until the steering wheel wont turn anymore.
Don't try to take the keys out yet, instead put the car in park and fire the car up, it should ignite now. THEN take out the keys.
Old Nov 30, 2006 | 02:41 PM
playa7970's Avatar
check you shift **** usually over time this comes loose did you change this with a aftermarket ****? if so then thats your prob
Old Nov 30, 2006 | 03:09 PM
2000GTP's Avatar
I have a similar problem at times. My console is getting old and worn I guess because if I dont push the shifter into Park hard enough, it will not allow me to get the key out of the cylinder. A little extra nudge on the shifter and boom, the key comes out.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
