ignition problems????
Old May 19, 2004 | 04:44 PM
got8?'s Avatar
over the past like 6 days my car has had this hesitation and it seems to be getting worse and worse but is only really bad when the car is really hot and the check engine light will flash but will go off i was thinking it was my plugs im not sure if they have ever been changed so i looked at one and it looked like it was fine but just old the only thing i have gotten done to my car and it does tend to blow a little black smoke when i rev it i am just clueless and the hesitation only happens when the car is between 1000-2000 rpms at any speed but its particularly in first and second gear i just need help i cant figure out what is wrong!!!
Old May 19, 2004 | 05:09 PM
slopokrodrigez's Avatar
By all means, change the plugs as soon as you can but consider the EGR. Typical hesitation problems at slow speed is usually due to a sticking EGR. Best to take it off, clean it, test it by sucking on the hose and letting off to see if its moving correctly and replace it with a new gasket.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
