Ignition Problem help me
Old Apr 25, 2010 | 06:47 PM
  #16
Guest47904's Avatar
Guest
Not an OBDI PCM never seen one bad ever.
Old Apr 26, 2010 | 02:04 AM
  #17
sburnsy's Avatar
So what does that leave me with I don't see how it's the opti since iv had 2 and it has the same problem
Old Apr 26, 2010 | 04:51 AM
  #18
Guest47904's Avatar
Guest
Assuming for the moment it truly does NOT have spark to those 2 cylinders. You need to monitor the IC signal from the PCM to the ICM to see if it's dropping out. Need a scope to do it.
Old Apr 26, 2010 | 05:53 AM
  #19
maddog05's Avatar
An old style scan using an ocilliscope can ID the 95Z problem
IMHO ~I feel it is still the opti again and the knowledge that you just replaced it & the difficulty of redoing it keeps contributes to your reluctance to agree. If you truely got the GM unit - it makes no sense. There are many imitators because of GM's high pricing. Without on the spot observation you may wish to scan it at an old AUTO ELECTRIC since 95's did not have OBII ~ costs about $85.00
Old Apr 26, 2010 | 09:16 AM
  #20
sburnsy's Avatar
Ok well I will see if I can rent an oscope from some where and if I get a good signal then Ill look into getting that scanner thanks for the help
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
