Ignition prob or need new battery?
Old Jun 15, 2004 | 11:33 PM
RED95LT1Z28's Avatar
Question Ignition prob or need new battery?
Alright here's the deal.....every so often for the past couple of days i go to start my car and it starts and then it dies like right after...i go to start it again and it starts and dies right after...it doesn't even idle. But then i go to start it again and it's fine and it drives fine under WOT and everything. Now sometimes it starts up fine no problems. It's like 7 out of 10 times it'll screw up. What could this be?
Old Jun 16, 2004 | 05:08 AM
slopokrodrigez's Avatar
I don't think it's ignition or battery. If the battery were causing it to shut down, you wouldn't be able to crank it back up. Could be spark plugs but doubt it. Could always put in a fresh set. I think you have a fuel problem. As in restricted injectors. I would have them cleaned professionally and perhaps even have them flow tested.
AtlasXVIII
Aug 24, 2015 11:41 PM
weedog
Aug 15, 2015 08:23 PM
cmsmith
Aug 9, 2015 07:30 PM
RUNMYTA
Jul 15, 2015 07:50 PM
