Ignition coil question
Old May 24, 2006 | 11:13 AM
wicked_95z's Avatar
Is the coil supposed to be loose in that metal bracket that surrounds it??
Old May 24, 2006 | 11:48 AM
Re: Ignition coil question
No. That would produce poor grounding of the coil.
Old May 24, 2006 | 02:52 PM
wicked_95z's Avatar
Thanks Shoebox
Old May 28, 2006 | 07:02 PM
KPZ-28's Avatar
Is the laminated outer core (I think thats what you call it) supposed to be loose or have slop around the center windings (the center part of the coil with the connectors)? My new coil has this movement and I wonder if were talking about the same thing?
Old May 28, 2006 | 10:35 PM
I thought you were referring to the mounting of the coil to the coil bracket. I have noticed a little play in the epoxied part of the coil in relation to the square metal core surrounding it. That seems to be normal (if not in excess).
Old May 28, 2006 | 10:52 PM
KPZ-28's Avatar
thanks shoebox, thats one less thing I need to worry about in solving my missfire problems!
btw- my old coil had 5800 ohms cold, was it ok or did it need replacing? The new coil has 8200 ohms and I still get missfire when warm?
Old May 28, 2006 | 11:01 PM
Either is probably ok.
Ari G
Dec 11, 2014 03:21 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
CARGASM
Sep 4, 2002 11:17 AM
