ignition coil
Old Aug 17, 2015 | 10:07 AM
  #46
markzzzz's Avatar
Re: ignition coil
Been running great for about a thousand miles but just started hearing a random pop (backfire?) from the exhaust. Have a misfire code on cylinder 8 but plug and wire looks good. No power loss or engine cut back. Could it be a cat going bad? Only happens at idle when hot.
Old Aug 17, 2015 | 11:08 AM
  #47
Re: ignition coil
If it's only #8, its most likely specific to #8 - plug, injector, contact in Opti cap, corrosion on wire in Opti end, bad valve, etc.
Do you have access to a scanner with "GM Enhanced Parameters", that will allow you to check the misfire count on all cylinders, to see if it really is specific to #8?
Kempster
Jul 7, 2020 11:00 AM
asilomar244
Jul 12, 2015 05:53 AM
robyyzpapa
Jul 7, 2015 10:05 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
