ignition coil
Old May 31, 2015 | 05:01 PM
  #31
Re: ignition coil
Originally Posted by markzzzz
I decided to change the optispark with a Delphi one that I had as a spare. I took the one that I had taken off apart and it was full of grime and such. It had a really weak looking seal and I think the vents were hooked up wrong. As I understand one of them goes to vacuum on the manifold and one goes to intake elbow between air filter and maf sensor, correct? I don't want the same thing happening again.
http://shbox.com/1/opti_vacuum_harness.jpg
Old Jun 1, 2015 | 12:23 AM
  #32
markzzzz's Avatar
Re: ignition coil
I don't have an elbow there. I have a k &n air filter that has a hole larger than the vacuum hose but it's between the filter and the maf sensor.
Old Jun 1, 2015 | 08:08 AM
  #33
Re: ignition coil
The larger connection midway between the filter and the MAF sensor is the connection for the air supply to the AIR pump. Has your AIR been deleted? If so, that connection should be closed off.
95-97 should have the hole in the RUBBER intake elbow between the MAF sensor and the throttle body. If your 97 elbow doesn't have one, you have the 93/94 intake elbow. Drill a hole in the rubber elbow slightly smaller than the blue plastic vent line elbow, and push the blue plastic elbow into it.
The connection for the Opti vent needs to be AFTER the MAF sensor, because that air ends up in the intake manifold, and has to be accounted for as part of the air/fuel calculation.
Old Jun 1, 2015 | 11:14 PM
  #34
markzzzz's Avatar
Re: ignition coil
I don't know if the air pump has been deleted. What's it look like and where would it be? Going to square up the opti vents tomorrow morning.
Old Jun 2, 2015 | 06:33 AM
  #35
Re: ignition coil
The AIR pump bolts to the front of the engine, driver's side, below the head.
Do not leave the hole in the air duct open... it would be allowing dirty air into the engine.
Courtesy of Shoebox
http://shbox.com/1/air_pump_recall.jpg
Old Jun 2, 2015 | 11:40 PM
  #36
markzzzz's Avatar
Re: ignition coil
I think I almost have this whooped. I'm getting a skip shift selonoid code. Where is it at?
Old Jun 3, 2015 | 09:09 AM
  #37
Re: ignition coil
Driver's side of the T56 manual transmission.
Go back and read my earlier response:
https://www.camaroz28.com/forums/lt1...9/#post6976760
Old Jun 3, 2015 | 09:29 AM
  #38
markzzzz's Avatar
Re: ignition coil
Aside from a small drip from a heater hose (replacing in the morning), I think it's all squared away. Thanks for all the help, hope I can pay it forward one day.
Old Jun 9, 2015 | 11:58 AM
  #39
markzzzz's Avatar
Re: ignition coil
Cranks and runs perfect. After about 30 minutes ses light came on. Scanned and got P0140 and P0160 oxygen sensor no activity bank 1 and bank 2 respectively. Going to look for a loose harness but will these harm anything. Also when starting it when hot it seems to struggle at first then starts within a few seconds. Starter may be getting weak or have a bad spot that shows up when hot?
Old Jun 9, 2015 | 12:54 PM
  #40
Re: ignition coil
Those codes are for the after-cat sensors. They don't control anything, just there to see if the cats are working. Is it possible someone has removed the cats and replaced the O2 sensors with "O2 sims"?
Old Jun 10, 2015 | 08:05 AM
  #41
markzzzz's Avatar
Re: ignition coil
That's good to know. I'll check it out on Friday morning. Seems to be running pretty good overall. Holding my breath and hope it stays that way.
Old Jun 13, 2015 | 01:30 PM
  #42
markzzzz's Avatar
Re: ignition coil
Nothing new but why does the ses light blink sometimes? It's on because of year 02 sensor but it has started blinking every so often.
Old Jun 13, 2015 | 02:53 PM
  #43
Re: ignition coil
SES blinks when the PCM detects engine misfires that could damage the catalytic converter.
Old Jun 16, 2015 | 06:34 AM
  #44
markzzzz's Avatar
Re: ignition coil
Any misfire info comes from the crank position sensor, right?
Old Jun 16, 2015 | 07:15 AM
  #45
Re: ignition coil
The PCM uses the data from the CKP sensor and the cam position sensor in the Opti.
