If the 10-bolt doesn't break...
Old Jun 26, 2003 | 09:41 PM
Brent95formula's Avatar
I know a 12bolt/9" is way stronger. Would you see approx. the same gain from 4.10's in a 10-bolt as you would in a 12-bolt?
If I just throw in some 4.10's in the 10-bolt and run et streets a couple times I should be okay....right? By the way, what gains should i see going from 3.42's/2.3 60fts to 4.10's/1.8 60 ft's (hopefully)?
Old Jun 26, 2003 | 10:24 PM
1QUIKTA's Avatar
Will it be OK? I doubt it, but you may get those couple runs in before it goes BOOM. You do have a M6 car, right? I took out my 3.73s with a set of BFG DRs and I was on my 4th run with the combo. Good luck though
Old Jun 27, 2003 | 06:47 AM
IDOXLR8's Avatar
I guess it will last if you are lucky. As stated above since you have an M6 it is alot harder on a stock rearend since it shocks the drivetrain when you drop the clutch.
Old Jun 27, 2003 | 09:19 AM
Dave Feerst's Avatar
The only difference besides duribility is that the 12 bolt weighs more. And the 9 inch weighs even more still. So all things being equal the larger axles would cost you time. But then you have to consider the weight is right where you need it, on the rear axle....
I dont think the 10 bolt holds up well to slicks. especally not in a M6... You should work on pulling your 60 foot times down. you obviously had really bad tires or a bad track. most stock LT-1s can pull 2.0-2.2 60 foot times with a good driver....
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
Toxintwins
Sep 11, 2015 11:13 AM
