idling weird
Re: idling weird
I guess I'm not really on board with a vacuum leak causing a hunting idle. A leak usually leads to elevated engine speed but not the oscillating one.
My guess would be that the IAC is trying to compensate for something else......a bad TPS comes to mind.
The best way to figure this out is to use a scanner to see what the computer is seeing and doing. If you don't have a scanner you can download TTS data master and buy a cable...you'll be set to run logging scans.
I have seen something like this with fouled plugs. However,that was a case of the idle starting low and going lower....
Re: idling weird
ALL THE HOSES.....are good no leaks i researched and found out a vacuum l eak doesn't cause high idle,if i had a vacuum leak id lose power have poor acceleration stumbling,i dont have none of that,im leaning to the spark plugs its been 4 years since i changed them.
Re: idling weird
I think i didn't explain it right guys the idling isnt high it goes goes to 1100 to the most 12 or 13, but my engine isn't running rough it just sounds like sum1 is pushing the gas when it idles up,i checked every vacuum hose like joe said all are fine.maybe shoebox or Fred can can fix this
Re: idling weird
Re: idling weird
Joe speaking of scanning i have an engine light on it only cones on a few seconds after the car is running. the idling is way better now,not idling so high no more. But the obd1 scanner i have i followed all the directions i connected it entered the data it asked,turned the ignition on,then it says the vehicle isn't responding,i even took it to a shop n they couldn't even pull the codes on their diagnostic
Re: idling weird
Hey guys i have the results to the diagnosis
1.the egr valve isnt opening
2.the map sensor is at 2.41 volts should be at least at 5
3.the tps sensor is @ 1.24 n should be close to 1.33
4.the knock sensor is malfunctioning becuz the tps isnt adjusted to the correctly
Now guys my buddy told me to start with the egr valve do i change the egr valve or the egr vacuum solenoid. Bc i dont throw parts n waste money.
Re: idling weird
Re: idling weird
Under what conditions did you get the sensor measurements posted? With the throttle closed, for example, the TPS should read between 0.20 - 0.90V. Anything outside those limits will set a code.
The MAP sensor reference voltage is 5.0V. When you turn the key on, but don't start the engine, the MAP sensor will read baormetric pressure, giving a voltage of 4.5 - 5.0V, depending on the elevation where you live. At idle, you would see about 1.2 -1.4V. But depends on how much vacuum the engine is pulling.
The knock sensor does not work incorrectly because of TPS voltage. The PCM simply checks the voltage on the knock sensor circuit to make sure it's between 1.5 - 3.5V.
Re: idling weird
That is wat the scanner said the key was turned on but the engine wasn't running and i did tell u what the scanner said so dont u tell me i didnt.i was born and raised in the u.s.a. so im not an idiot
Re: idling weird
If there are no codes, post that as well.
What I think would really help is if you could get a logging scan done. That would show what is going on in real time and not a point in time that the regular scanners show. If a logging scanner is not available to you, all you need is a laptop and a cable...there is software that can be downloaded.
