idling weird
Old Oct 24, 2012 | 02:46 PM
94Z28LS1toLT1's Avatar
idling weird
Hey guys no ses light on.my idling is going from 1100 to 800 just jumping in those places then stays perfect at 900,but sounds like im pushing the gas when idles up n down but my foot isn't even on the gas where should be the 1st place to start.it didn't start till now bc my bro in law borrowd it for a month,n when i had it it never did this
Old Oct 24, 2012 | 05:05 PM
RamAir95TA's Avatar
Re: idling weird
Check for vacuum leaks around the throttle body, intake elbow, etc. Also it would help if you could monitor your IAC counts to see what the IAC is doing.
Any recent work done to the car?
Old Oct 25, 2012 | 08:11 AM
Re: idling weird
Joe thank u for ur reply all hose are great,my bro in law told me he put 711 gas instead of chevron or shell gas,it started after he put the 711 one in but im warming up it now n its idling better ill keep u updated
Old Oct 25, 2012 | 07:00 PM
Re: idling weird
Hey joe the car is still idling a lil hight like 1100 but not as much. no recent work done on the car,its just been borrowed by a family member,but i think the iac sensor can be dirty,wat are the signs of a bad iac sensor?
Old Oct 29, 2012 | 09:31 PM
Re: idling weird
I checked the iac sensor it was pretty dirty, i noticed it had a spring in it now is that spring supposed to move up and down? Bc mine doesn't move up and down. Now i also noticed my elbow for the air filter that inserts in the throttle the nipple broke, now that hose that comes from the vented opti,would the line being out of the elbow cause it to idle high im idling at 1200 now
Old Oct 31, 2012 | 07:51 PM
Re: idling weird
I changed the iac valve to be safe idling is still the same 800 too 1200 when i turn the car off the on the idling goes to 1500 n stays there for awhile like at least a minute.then will go to 900 and still idle up n down.i looked in the haynes book and found excessive high idle n all it says is sticking throttle linkage and idle speedim at a loss incorrect.what else is thete to check guys
Old Nov 1, 2012 | 10:00 AM
Lilatlboy6969's Avatar
scan it to see if the coolant sensor in the radiator has gone bad. it should show a different reading on your dash than what the ecm is seeing if it is bad
Posted from Camaroz28.com App for Android
Old Nov 1, 2012 | 01:50 PM
ACE1252's Avatar
Re: idling weird
The sensor you refer to is in the water pump, not the radiator.
Old Nov 1, 2012 | 02:04 PM
RamAir95TA's Avatar
Re: idling weird
And to further complicate things since the two sensors are in two completely different places they almost never read the same (cylinder head reads hotter than water pump, obviously).
Old Nov 1, 2012 | 02:32 PM
Re: idling weird
Ill get it scanned today n see but the sensor on the radiator does it really have anything to do with the idling
Old Nov 1, 2012 | 02:34 PM
Re: idling weird
Hey ace the one on the water pump is new the senor.but myin my car is fine
Old Nov 2, 2012 | 01:07 PM
ACE1252's Avatar
Re: idling weird
It's possible that it could be a vacuum leak. It's also possible that it could be bad gas as well. I got some bad gas one time in my 3.8 V6 Camaro and it was idling like a 427 with glass packs it was so bad.
Scanning it and watching the IAC position could help in determining what action to do next.
Move around and check all the hoses connected to the intake manifold with it running to see if the idle jumps around.
Old Nov 2, 2012 | 01:09 PM
ACE1252's Avatar
Re: idling weird
No. The sensor in the radiator is simply for the low coolant level light on the dash instrument cluster.
Old Nov 2, 2012 | 04:21 PM
Arrow Re: idling weird
Hey ace thank u also is there anyway i can get a diagram of all the hoses that way i can see where i needs to look and check
Old Nov 2, 2012 | 04:50 PM
RamAir95TA's Avatar
Re: idling weird
There is a diagram of all the vacuum lines and hoses under the hood (believe it or not).
