Idling problem
Old Aug 18, 2005 | 09:22 PM
rsjay's Avatar
Idling problem
I have a 1994 LT1 Camaro with hotcam, 1.6 RR, headers, 3" exhaust, pcmforless custom tune, and pretty much any other bolt on. I just completed the rebuilding the motor and also have new bearings, gaskets, timing chain. I ran the car for about an hour then took it for a spin but idling still below 500 rpm's. It will not idle on its own. I checked for vacuum leaks but found nothing. Anything else I should be looking for??
Old Aug 19, 2005 | 09:15 AM
Re: Idling problem
What idle speed did they program it for? Is it an A4 or M6? What throttle body are you running? Did you check the IAC counts? Are you sure the IAC motor is plugged in and working?
Old Aug 19, 2005 | 09:19 PM
rsjay's Avatar
Re: Idling problem
The idle speed was suppose to be around 800-900 rpm. My iac is plugged in. I have a stock trottlebody. Maybe I just need to drive the car more for the computer to re-adjust for all the mods.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
