idle problems?????
Old Sep 7, 2007 | 10:53 AM
osolow's Avatar
idle problems?????
I have a le2 383. sometimes it wont start unless you give it some gas. when I turn on the a/c it trys to die. any sugestions?
Old Sep 7, 2007 | 12:21 PM
How do you "give it some gas"? Moving the throttle at startup doesn't really do anything besides let more air in. If you put it on the floor, the PCM goes into "clear flood" mode.
Sounds like your IAC motor may not be working to control the idle speed. What throttle body are you using? Some appear to cause problems with the functioning of the idle air path.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
