Timing
Old Sep 5, 2007 | 05:03 PM
Bails098's Avatar
Timing
Im tryin to set up my timing with my msd cap and rotor, when my motor is at top dead center should it be firing cylinder 1?
any suggestions on setting this up
Old Sep 5, 2007 | 05:06 PM
dangalla's Avatar
ahhh... what exactly are you trying to do
is this an lt1 with an opti
the opti will only slide into the drive in one position easily
Old Sep 5, 2007 | 05:12 PM
Bails098's Avatar
Yes it is an LT1 opti but i dont think my timing is correct it is not runing right
Old Sep 5, 2007 | 05:16 PM
dangalla's Avatar
when you put the opti back on did it slide into position or did you force it into place
what exactly do you mean by not running correctly, does it have any codes
Old Sep 5, 2007 | 05:26 PM
Bails098's Avatar
when i put the opti back on it will go on several different ways and it sounds like it is misfiring
Old Sep 5, 2007 | 05:34 PM
Stl94LT1's Avatar
Timing is set by the PCM. You need to make sure the opti is installed correctly. I know the MSD unit has an adjustment screw. But, if it's not installed properly that screw isn't going to help.
Old Sep 5, 2007 | 05:35 PM
jasonisdn's Avatar
make sure the dowel pin fell into the correct hole. i would say you missed but its hard to do, cause the pin is longer than the other holes are deep.
Old Sep 5, 2007 | 06:49 PM
...it depends on which cylinder you have at TDC...
Old Sep 6, 2007 | 06:07 PM
You might want to provide a "signature" with basic info about your car, inculding the year, model, tranny, etc. The Opti has two different drive designs, depending on year. Without knowing which one you have, it makes it harder for people to suggest possible causes of the problem.
Old Sep 6, 2007 | 06:24 PM
96capricemgr's Avatar
Before buying an MSD opti you should have a keyed hub, degreed damper and fabricated a timing pointer, otherwise you are just guessing.
It sounds to me like you are on the verge of costing yourself a lot of time and money. Last guy I knew who said the things you are, broke the timing adjustment on the MSD and had to go back to stock then I found some mixed up plug wires for him. The plug wires were the problem and in an effort to "tune" with the MSD timing adjustment he cost himself $500 and days of wasted time.
If you have the stocker try it and see if the car runs right.
Old Sep 7, 2007 | 12:33 PM
Since he only has the MSD cap and rotor, I think he's just trying to insure he has the Optii indexed correctly to the cam. I don't think he is trying to use the MSD timing feature, since that's on the body of the Opti.
Without knowing which drive he has, we're sort of spinning out wheels.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
