idle problems
Old Feb 29, 2004 | 06:19 PM
fstenuf's Avatar
idle problems
idk what the deal is it just started happening to me today...
on my way home from a nice sunday morning cruise, my car was being kinda hesitant adn when i came to a stop sign it died on me it ussually idles at 1000-1100 rpms then it went to 500 then it died... idk what the deal is, i fired it up later this afternoon and it did the same thing. any info would be greatly appreciated.
Old Feb 29, 2004 | 07:57 PM
fstenuf's Avatar
Question
anyone?
Old Feb 29, 2004 | 08:10 PM
Idle speed is controlled by the PCM, using the idle air control (IAC) motor in the base of the throttle body. Possibly the IAC motor is faulty, the wiring is faulty, or the IAC passages in the TB housing are plugged up. Could also be a sign that the TB was not set up properly when it was installed, checking to insure the IAC counts in the PCM are in the range of 20-40 when the engine is idling at the RPM programmed into the PCM.
Old Feb 29, 2004 | 08:34 PM
fstenuf's Avatar
how do i check to make sure that is the problem? do i take it to a shop and have em hook the beast up to see whats wrong with it or won't that help....
the CPU was programmed by ed wright with a list of all the engine info, when the engine was installed.
Old Feb 29, 2004 | 08:50 PM
You need to put a scanner on it and look at how the IAC counts are reacting to the incorrect idle speed. IF the PCM is increasing the counts, but the idle speed isn't coming up, you know that you have one of the above problems.
Old Mar 1, 2004 | 10:45 PM
fstenuf's Avatar
where is the ica motor and the passages in the TB? and could i clean them out myself? is the ica motor something that can be replaced or fixed? thanks for the help
Old Mar 1, 2004 | 11:32 PM
When in doubt, go to Shoebox's tech pages, and pull up a picture.....
IAC motor
The idle air enters through a hole in the bottom triangle between the throttle bores in the throttle body, and goes into a removable cover plate on the bottom of the throttle body, where the IAC motor is located.
Old Mar 2, 2004 | 11:04 PM
fstenuf's Avatar
how hard is this to fix? i'd like to try to attempt to clean it myself. can you buy the IAC unit by itself or do i just clean it really well and put it back together? any info on doin this project would be great. thanks
Old Mar 3, 2004 | 12:51 AM
96ta(nick)'s Avatar
you can buy just the IAC it is 55bucks at autozone though.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
