Idle Problem Semi-Fixed
I went over it with a fine tooth comb yesterday. Nothing loose or disconnected.
One thing I have learned is that the bad idle situation didn't present itself to the previous owner until he did an auto to M6 swap. Any ideas why this could be?
I have the idle problem but mine just drops way down...eventually it will come back up after stopping the car for a couple seconds. I also did an auto to m6 swap but it didn't start right away either.
Joe
Joe
Nevermind, I forgot you had a '93. We swapped a buddy of mines '95 to a M6 and he still doesnt have things working right. He found out that the only way to get it done right is to get the M6 computer.
I am not sure if the IAC setting would be changed or not? Was the chip put in the car when it was an auto?
Originally posted by ONELOUDKAR
hey SHOEBOX, what should the IAC counts be.. i have a log and was wondering where they should be?
ok SHOEBOX, my counts are anywhere from 20-40 at idle and i have the cc305 cam in it. could this be my problem? a couple of times it would jump up to 46 or so. not often though. i can send you a copy of the log if you would look at it for me..
thanks
Mike
thanks
Mike
The car got a new chip at the time of the M6 swap.
I'm really inclined to think that it's a faulty IAC at this point due to the fact that it idles fine with the IAC unplugged. Hopefully, withing the next few days I'll be able to put a laptop on it and see for sure.
Magenta_Hearts
Mar 5, 2015 07:01 AM
slothgrant
Aug 22, 2002 03:01 PM
