Aftermarket Heads
Old Aug 14, 2003 | 07:14 AM
SantaCruz163's Avatar
Aftermarket Heads
I'm curious what LT1s have for choices on aftermarket heads? You can't use any SBC heads because of the reverse coolant flow, so what is out there specially designed for LT1s. All I know for are AFRs.
Old Aug 14, 2003 | 07:18 AM
predator's Avatar
the best thing to do is get the stock lt1 heads ported and polished
Old Aug 14, 2003 | 07:27 AM
Well what would you use if your goal is to have 700+hp. I'm sure you wouldn't use ported stock heads. I just wanna know what LT1s have as options on aftermarket heads.
Old Aug 14, 2003 | 07:37 AM
G-Racer's Avatar
Why not rework your heads? You would be pleasantly suprised.
Old Aug 14, 2003 | 08:12 AM
Fastbird93's Avatar
Depending on your combo, you could feasibly get 700 out of a well done set of stock p&p heads. NOT N/A mind you, but on the right application I think it could be done.
Old Aug 14, 2003 | 08:34 AM
So its not worth buying aftermarket heads? Just redone the stockers. Well they be able to flow as well as the aftermarket ones? Can you put bigger valves in them ie. 2.08 & 1.65?
Old Aug 14, 2003 | 08:42 AM
Fastbird93's Avatar
Yes you can put in bigger valves, not quite a 2.08 though. My heads, for example, have 2.02/1.55 valves, and flow 274@.550, but the mid lift numbers are where they stand out. At .400 they're flowing low 250's.
The downside to the stock ported heads is that if you're building a large high revving motor, they won't be able to support it. Then, you'll need something aftermarket with larger runners.
Old Aug 14, 2003 | 09:18 AM
RealQuick's Avatar
Nobody has answered your question yet, so here ya go:
LT1 Stock heads (GM)
LT4 Heads (GM)
AFR Heads (LT1 to LT4 with various cc sizes)
Edelbrocks
Dominion (4Valve Heads)
Old Aug 14, 2003 | 12:08 PM
Add to the above list:
Canfields, if you can find a used set, because they stopped making them.
The world's quickest LT1 (9.04@155, 1,125HP) used a set of highly modified Canfields. Before he went over 1,000HP, he was using a set of LPE CNC LT4 heads, with a little extra tweaking.
Rod Bender
Jan 1, 2015 03:18 PM
TireSmoke
Aug 6, 2002 10:25 PM
Snake Slayer
Jul 29, 2002 12:39 PM
95 Mystic TA
Jul 29, 2002 08:50 AM
