idle problem
Old Feb 9, 2006 | 07:23 AM
96Z28fella's Avatar
idle problem
when my 96 Z is idling sometimes it will idle correctly and other times it will idle real low like 500rpm's it also will sometimes shut off when at idle. I did get rid of my cats and my o2 sensors are obvisouly not funtional...any ideas why the bad idle?
Old Feb 9, 2006 | 12:57 PM
OBE1 95Z28's Avatar
Re: idle problem
Idle air control may be dirty. Also check for vacuum leaks.
http://shbox.com/1/iac3.jpg
Old Feb 9, 2006 | 04:42 PM
96Z28fella's Avatar
Re: idle problem
thanks ill have to give it a look..thanks for the info
Old Feb 10, 2006 | 05:00 AM
Guest47904's Avatar
Guest
Re: idle problem
The IAC could very well be dirty but that usually makes it idle too high since the pintle can't get close enough to shut er down. Your problem sounds like a sticky EGR. You ought to pull it out and see how dirty that thing is.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
