Idle problem
Old Jan 4, 2005 | 05:34 PM
importfyghter's Avatar
Idle problem
I have a 94' Camaro Z28 with 38K on it. I put the car up in october and it has been sitting ever since. Yesterday i pulled it out and put my new stripe on it. Well i didnt realize i didnt have much gas in it so it stalled/ran out. I pushed it back in the garage and let it sit over night..today i went and bought some gas and put it in and fired it up. Now its popping and studdering and making a Ticking sound when i hit the gas. Could it be the gas? Maybe has moisture in it or sumthing. I let the car warm up and everything..still nothing. Help me out guys.
Old Jan 4, 2005 | 06:53 PM
red 95 z28 lt1's Avatar
Re: Idle problem
your filter or pump may be clogged with particales at the bottom of the tank or maybe some condinsation in the tank from sitting empty so long. check/change the fuel filter. maybe check the fuel pressure. it sounds fuel related
Old Jan 4, 2005 | 08:14 PM
OBE1 95Z28's Avatar
Re: Idle problem
If you're going to store a car for any period of time, make sure it has a full tank of gas. This reduces the change of absorbing moisture in the gas. I would try adding a can of dry gas to absorb any moisture that's in the gas. Also hook up a fuel pressure gauge to the schrader valve on the fuel rail and verify you have proper fuel pressure to see if your fuel pump is working properly.
Old Jan 5, 2005 | 10:11 PM
Re: Idle problem
Well the reason it didnt have any gas in is is because i really didnt plan on putting it up that soon, i just kinda parked it because i bought a second car. Kinda forgot about it not having gas in it. I bought some dry gas and a new filter tonight and ill put it in tomorrow. I figure id change it anyways since it couldnt hurt. Ill let ya guys know, thx for ur opinions...
Old Jan 6, 2005 | 12:06 PM
Re: Idle problem
Well guys i fixed the problem, I put some fuel treatment in there and added more gas. I let it warm up and she runs alot better now.
Old Jan 6, 2005 | 03:17 PM
Re: Idle problem
there was probably crap in the lines or a little water. glad to hear that its fixed
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
