idle issue
Old Jun 6, 2009 | 01:30 AM
95_formula's Avatar
idle issue
so i just installed a 52mm tb and now the car idles very low and will sometimes die but only in closed loop mode. tps is good, no vaccume leaks, and iac is good. any ideas?
Old Jun 6, 2009 | 01:53 AM
awill12's Avatar
what kind of tb did u buy?
Old Jun 6, 2009 | 02:51 AM
95_formula's Avatar
summit lt1 52mm
Old Jun 6, 2009 | 05:40 AM
Guest47904's Avatar
Guest
What are the IAC counts?
Old Jun 7, 2009 | 03:25 PM
95_formula's Avatar
how do i get the counts?
Old Jun 7, 2009 | 08:59 PM
You need an OBD-I scanner, and it has to have the adapter to connect its 12-pin connector to your 95's 16-pin ALDL connector. Or use the jumper wires shown on Shoebox's site:
http://shbox.com/1/xraycable.jpg
Old Jun 8, 2009 | 03:14 PM
95_formula's Avatar
alright cool thanks, looks like i need to get some lt1 software or something. any recomondations?
Old Jun 8, 2009 | 03:56 PM
JAKEJR's Avatar
When I installed a new BBK 58mm TB on my 388 I had to open the butterflies a bit even though the directions that came with the TB claimed it was supposed to be a bolt one, factory set, blah, blah, blah.
I used the minimum airflow adjustment screw to open the butteflies. After doing that the IAC counts came down to the mid 20's and, after the engine was shut down and re-started, the engine idled at the PCM re-programmed idle speeds from then on.
Tweaking is all mine needed.
Jake
West Point ROCKS!
Old Jun 8, 2009 | 05:32 PM
NJ-LE's Avatar
95_formula:
Get an interface cable
(I went to Tunertools.com ... http://tunertools.com/ALDL_Cables.asp)
and a copy of Freescan just like the title says - no cost.
(http://www.andywhittaker.com/ECU/Fre...0/Default.aspx)
It will provide the TPS and IAC data you need plus a good deal more. Wherever you get the cable at, tell them you've got a '95. The cable/connector configuration is different from other years.
Good Luck
Old Jun 8, 2009 | 11:32 PM
Or:
DataMaster downloads free, but requires a license after 20 uses:
http://www.ttspowersystems.com/
http://www.akmcables.com/
Dark Zeiro
Mar 11, 2015 07:15 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
