Bogging and Backfiring!!
Old May 14, 2009 | 09:54 AM
jeremyw2585's Avatar
I just put the motor back in my car a week or 2 ago. It has been running and driving great until the other day when it just suddenly started bogging really bad and backfiring a little. It feels really weak until I hit wot and it seems to clear up for a sec. until I let off. Even while it is idling it sounds weird (not missing). Even when I hit the throttle in park it bogs really bad. I have new ac delco 02 sensors and there is no exhaust leak. I unhooked the maf and it didn't change. Could someone help me figure this out?
Old May 14, 2009 | 10:25 AM
SnakeSkinner28's Avatar
Check for a vacuum leak, arching wire (might have a wire near the header or something), is it throwing a code? Check the O2 sensors, could be the opti crapping out, there are a lot of possibilities especially if you just put the motor back in...
Old May 14, 2009 | 11:46 AM
I checked for vacuum leaks and burnt wires. I will check to make sure all the wires are snap on the plugs and opti. No SES light.
Old May 14, 2009 | 01:41 PM
what year is the car? stock motor? how come the motor was out etc...i guess more info the better since this problem could be a sh!tton of issues...
Old May 14, 2009 | 01:52 PM
It is a 94 z28 with heads and cam. I pulled the motor to build the bottom end up. Also right before it got really bad it would only bog down when I hit the throttle fast. If I eased the throttle down it wouldn't do it. I have a descent sized cam in it and now you can't even hear it. It has a lope, but a different kinda lope than the cam makes.
Old May 14, 2009 | 02:49 PM
Another thing is that since I put the motor in the fans have not came on. I had to wire a manual switch.
Old May 14, 2009 | 03:12 PM
Have you gotten it tuned??
Old May 14, 2009 | 03:19 PM
Yes it has been tuned. I don't think it is a tuning issue because it happened just all of the sudden. First it had a little bog and then I hit wot (not for the first time). Let off and it went crazy. I have been thinking and I am gonna clean the MAF and change the temp. sensor in the water pump when I get home from work.
Old May 14, 2009 | 04:44 PM
93FIRETURD's Avatar
Check your fuel pressure if the pump went bad you would have the said symptoms. Good luck!
Old May 14, 2009 | 05:05 PM
I hope it is not the pump. It is a brand new walbro.
Old May 15, 2009 | 02:44 PM
Hal Fisher's Avatar
I think bogging is always fuel. Use the "trap door" method for replacement. If it's new than it should be under warranty.
Hal
Old May 15, 2009 | 08:49 PM
Venomous360's Avatar
Mine is doing the same thing, I think mine is the Opti going to swap it out this weekend.
Old May 15, 2009 | 08:58 PM
The SES light finally came on today. It read code 26 (output drive module). I think this has something to do with the ecm. Could someone with experience help me out with this?
Old May 16, 2009 | 05:44 PM
Checked fuel pressure. With key on car off it is 40 psi. With the car idling, or reving it stays 45 psi.
Old May 16, 2009 | 08:55 PM
WhiteThunderZ28's Avatar
It could be your IAC... I had the same symptoms when I installed my cam... It would miss and backfire, so I put my old IAC back in and the car ran fine. Ended up that my IAC was able to move around in the housing that it was secured in... I almost thought it was the opti since it sorta has the same symptoms when it goes.
See if you can borrow somebodys IAC just to make sure.
