Idea for NOS setup.......
LT1 idea....
Since the opti- spark... cannot retard timing....
MSD Ignition required
Install an Adjustable Timing Control- PN MSD-8680
Load: Use a relay to control the power input to the timing controller...
ie: batt. to relay , Normally open contacts , to timing controller , to ground.
Power: The relay coil (control circuit) will be powered through the dash switch for the NOS system... through the throttle micro switch...
ie: when NOS is armed, so is the timing controller
Control circuit: The relay's operation is through the Throttle Micro Switch...
ie: timing controller becomes operational when Throttle micro switch is depressed...
Reason: Retain 100% timing untill micro switch is depressed,
do not loose any Naturally aspirated HP from retarded timing...
Benefits: Dont have to adjust the timing controller from N/A to NOS every time you want to spray..
Just thought i would share my idea...
whitehooptie
Aug 10, 2015 07:02 AM
michaelzilinski
Jul 31, 2015 08:41 AM
