Balancer from Camaro and Caprice LT1 different??
Old Sep 15, 2003 | 09:28 AM
R_Andersen's Avatar
I'm trying to finish up the 383 LT1 I'm building for a 93 camaro and I have a problem witht he balancer. The balancer i have is froma 94 LT1 Caprice and it does not appear to be correct. When it is mounted on the hub the balancer is about 1/4" to far forward and does not line up with the belt or other pullies. I have triple checked that the hub is fully seated on the crank so that is not the problem.
I'm wondering if the backspacing on the Caprice LT1 balancer is different than one from a Camaro or Firebird LT1 motor?
Any help with this would be greatly appreciated as this is the last peice in the puzzle to get this motor running,
Thanks,
Rob
Old Sep 15, 2003 | 09:57 AM
madwolf's Avatar
Was the Caprice a 4.3 or a 5.7? It would probably make sense for it to be different if it was from a 4.3.....
Old Sep 15, 2003 | 10:12 AM
R_Andersen's Avatar
It was a 5.7L caprice. I have the block sitting it the garage that I took the balancer off of, so I'm sure of it....
Old Sep 15, 2003 | 10:39 AM
bad79z28's Avatar
The F-body, Y-body and B-body all have different balancer spacing. I'm thinking that the balancer was the same, but the hub is different.
Kevin
Old Sep 15, 2003 | 11:00 AM
R_Andersen's Avatar
Kevin,
Thanks for the info. I have the original hub off of the 94 Caprice that the balancer came from and compared it to the 94 camaro hub I purchased for this car and the hubs are identical. I am buying another balancer from a 93 camaro to use so hopefully the difference is in the balancer and not the hub. Though I suppose it's possible that the hub I bought was misrepresented and actually came from a caprice also...
-Rob
Old Sep 15, 2003 | 11:05 AM
madwolf's Avatar
Rob,
can you get a picture of the balancer you have right now? I think it would a good idea to compare them before shipping...
Old Sep 15, 2003 | 11:14 AM
madwolf's Avatar
OK... just found some info:
Camaro-Firebird has a 1-5/16" thick balancer
Corvettes have a 2-1/8" thick balancer
"If using a Caprice, Impala or Buick engine it will require a crankshaft hub G.M. part number 12553250 used on 1992-95 Corvette and Camaro-Firebird engines. "
Hmm....
What's the thickness of your balancer?
Old Sep 15, 2003 | 11:44 AM
R_Andersen's Avatar
Hmm, interesting. I'm stuck at work right now so I won't be able to measure the balancer until I get home tonight. Does the source for that info list the thickness of the Caprice and/or Impala balancer also?
From that second part it certainly sounds like the impala hub is different that the camaro/firebird part.
Madwolf, would it be possible for you to pull the hub also? If it is indeed different I would be interested in buying that also since the ones I have must both be from caprice LT1's.
Old Sep 15, 2003 | 11:46 AM
madwolf's Avatar
Rob,
I'm not sure if I'll be able to pull the hub. Those things are a real PITA. I'll try though.
The website doesn't specify the thickness of the Caprice balancer. I got the info from here.
Old Sep 15, 2003 | 12:03 PM
R_Andersen's Avatar
Madwolf,
Thanks for all the help. It definately looks like the hub is different too, so if you could pull the one you have and send it with the other parts that would be great. Just shoot me an email if you do pull it with a price that you want for it so we can work something out.
Thanks,
Rob
SinisterRacing1
Mar 7, 2015 03:44 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
