IAT location
Old Dec 1, 2005 | 03:08 PM
chevyman502bb's Avatar
IAT location
i was inatalling my CAI and found that my IAT sensor was relocated by the last owner and i cant find the thing. it wasnt put where you would normaly relocate it to (near the air filter), so i cant find the freakin thing now.
so my question is where does the IAT sensor wiring originate? if i knew this i could simply fallow the wires to the sensor itself. any help is appreciated
Old Dec 1, 2005 | 03:31 PM
1SlowFormula's Avatar
Re: IAT location
Look here and scroll down to the close up shots of the intake elbow... You will see where I spliced into the wire and see the red/black wires going over the waterpump.. Those are for my relocated IAT sensor, that is sitting in my filter below my fender...
Old Dec 1, 2005 | 03:44 PM
Re: IAT location
thanks
well i found it, the stupid **** (i really hope your reading this, michael) just laid the damn thing behind the headlights.
think the sensor is still good? could the rain water and grime have made it gone bad?
Old Dec 1, 2005 | 04:22 PM
Re: IAT location
It easy enough to check it out. Hook an ohm meter across the pins, put it in a glass of ice water, and it should read approx. 9,420 ohms. Then put it in boiling water and it should read about 177 ohms.
I doubt that anything hurt it, but its worth checking out.
IndyZman
Oct 22, 2015 02:17 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
RobFlag
Aug 29, 2015 11:40 PM
Girrrrl
Aug 20, 2015 09:26 AM
