IAC wiring
Old Dec 31, 2019 | 07:04 PM
94Z28LS1toLT1's Avatar
IAC wiring
Hey guys I've been going thru stress and hell trying to pin why my camaro is starting then stalls. I've done all the fuel things. Pump,filter,regulator,checked injectors no leaks. I'm in the process of changing my dizzy I'm done with that now,just gotta put the water pump and all else back on.
Before I decide to put everything back on i decided to check the iac valve wires I noticed two are broken off out of the 4 that I see on the connector. I found the other two wires,would the two wires broken off be the issue to my start up and stalling the whole time.
This is what i found
now I can't tell which wires go where because they both look the same color green with a white stripe in the middle,any help is really appreciated. I looked at the ABCD on the wiring and the B and D are the ones that are not connected.
Old Dec 31, 2019 | 08:24 PM
Re: IAC wiring
Nevermind my wife helped me connect the wires and she found the right colors,and I connected them. The camaro is staying on and not stalling no more. After this whole time 😒😒😐🤐
Old Dec 31, 2019 | 10:06 PM
Re: IAC wiring
When you cold start the car, the PCM uses the IAC to elevate the idle, depending on the coolant temperature. The M6 program can raise the idle as high as 1,200 RPM at very low temperatures. If it can’t raise the RPM, it might stall. Unfortunately, there is no feedback to the PCM to tell it if the IAC is working or not, so no DTC code.
Old Jan 1, 2020 | 07:31 AM
Re: IAC wiring
cool thank you Fred I just can't believe the whole time because of two wires off the iac it caused this whole dilema. It's ok I'm happy as heck man that the camaro is not stalling anymore n stays running. 👍👌
BlazinREDZ28
Feb 15, 2008 03:49 PM
pHEnomIC
Dec 4, 2004 05:38 PM
1Qwik94Z
Sep 2, 2004 05:12 PM
neat
Apr 11, 2004 11:10 PM
BigTed187
Oct 7, 2003 03:34 PM
