iac bad?
Old Apr 17, 2024 | 10:21 PM
  #16
LT1DG's Avatar
Re: iac bad?
Originally Posted by Injuneer
You shouldn’t need a catch can, because the system shouldn’t be blowing oil into the throttle body. Some people experiencing oil flow used to use a small right-angle filter from Deutsch in place of the plastic elbow in the valve cover.
One “mod” that might increase the oil flow problem is modifying the valve covers for 1.6X full roller rockers. There is a small baffle on the passenger side cover, below the hole/grommet for the PCV vent line. If that baffle is removed, it can increase entrainment of oil droplets when there is backflow in the system.
So I guess that really bad then huh? Probably gotta get that check out then and I'm running stock valve covers
When people have this issue, how do they fix it? Cause I'm pretty sure I'm not the only one lol
Old Apr 17, 2024 | 11:11 PM
  #17
Re: iac bad?
Do a compression leak down test to determine the condition of the piston rings.
Old Apr 18, 2024 | 08:33 AM
  #18
Re: iac bad?
If you still have EGR, make sure the valve is not sticking open. That can cause stall issues when coming to a stop. This has nothing to do with the PCV tangent you are now on.
Old Apr 18, 2024 | 01:13 PM
  #19
LT1DG's Avatar
Re: iac bad?
Yea that probably what I have to do. Is this a normal thing that happens? What is the cause?
Thanks shoebox for the response 👍🏾 but my egr is deleted.
Like i mentioned above, I replace the hose under the throttle body because it was old & brittle and that made my idle a bit better.
The rpm drop when I slow down slightly die down, but still there.
Also last night when I put the car from drive to reverse, it died and fired back up. I plug the scanner in, and the iac count was at 160. But in park it settle down at 60
Old Apr 18, 2024 | 02:23 PM
  #20
Re: iac bad?
Those readings are too high. Either something is restricting air flow into the engine or in the IAC passages, or the IAC valve is not responding to the PCM's count command. There is no feedback to the PCM with regard to the IAC valves actual position, or whether the valve is even working.
From my experience, and indicated in my 29 page LT1 scanning guide, idle IAC counts should be in the range of roughly 20-40. As engine RPM increases, the counts should increase, typically in the range of 60-100. The value of 160 counts means the PCM has commanded the IAC to its maximum value.
https://www.camaroz28.com/forums/att...canning-r2.pdf
Piston ring blowby increases with piston ring wear and ring gummed up with carbon or sludge. But the LT1 engine, properly maintained, should nor experience that level piston ring wear at 80,000 miles. A possible cause of ring blowby is the engine running excessively rich, allowing raw gasoline to wash down the cylinder walls, removing lubricants.
You mentioned a damaged “hose under the throttle body”. What was that connected to? In 95 the PCV valve vacuum connection to the intake manifold is right below the throttle body. But 94 has the vacuum source is right behind the PCV valve on the side of the intake manifold.
http://shbox.com/1/pcv_pipe.jpg
There is an EVAP line running from the canister in the driver rear fender to the purge solenoid on the passenger side of the intake manifold.
http://shbox.com/1/1995_evap.jpg
Old Apr 18, 2024 | 03:00 PM
  #21
LT1DG's Avatar
Re: iac bad?
I haven't checked my air filter in a good while. Can that cause the iac to trip out if it's dirty? That literally the only thing, because of the location lol.
And yes that hose that I'm talking about, it connects to the pcv valve on the driver side.
I think my evap is disable in the tune, not sure. Isn't there a canister that is next to the gas tank that connect to the evap sensor on the passenger side? I didn't see one back there when I checked mines.
I don't know about the previous owner, but I have been taking good care of this car so far since I got it. It's not running that lean, cause on the scanner Long terms are usually around 134-140 and short terms cycle around 128-134. I am having spilt blm due to the iac issue.
I Wouldn't be surprise if the previous owner didn't treat it good.
Old Apr 18, 2024 | 07:07 PM
  #22
Re: iac bad?
Throttle blades opening all the way? Opening for the idle air that passes directly through the body into the intake manifold plugged or too small? That can be a problem with the Holley TB, requiring boring a hole in a blade. Some people have the split BLM's supposedly as a result of the restriction.
A restriction in the MAF sensor? I sold someone a CAI, threw a loose CARB-EO certification sticker in it. He didn’t realize it was there, ended up in the MAF. Not likely but had to ask.
Tolerance on the BLM's is +/- 5% versus 128. A 140 is adding 13% extra fuel - too much. Short terms should cycle both sides of 128, and average 128 over time. If the average short term is above 128, that’s when the PCM reduces the long term, trying to get the short term back to a 128 average.
Old Jul 6, 2024 | 03:39 AM
  #23
LT1DG's Avatar
Re: iac bad?
I know the holley is causing some idle issues.
​​​​​​Will a monified lt1 show the same readings as you stated on the BLM? Or will things show differently.
I forget I have a cam sometimes lol. I will assume a cam will probably changed the rhythm of the BLM. Or is my assumption wrong.
(Late Reply I know, been busy lol)
Old Jul 6, 2024 | 10:29 AM
  #24
Re: iac bad?
If the PCM has been tuned correctly for the modifications, the BLM's should be at 128 +/-5%. Bigger the cam, the harder it is to tune. Who did the tune?
White Knight 95
May 10, 2005 09:28 AM
atljar
Feb 27, 2004 11:10 PM
b-stevens
3rd Gen / L98 Engine Tech
Jan 10, 2004 01:00 AM
LT1RX7
Oct 16, 2003 10:08 PM
97 SLP Company Car
Apr 18, 2003 03:32 PM
