I have read I can't put a different timing chain on my car is that right?
Since i don't have the vent opti if i remember right thats why i can not have a diff chain than stock correct me if i'm wrong. Also would a new stock chain be alright with a XE cam like 224/230 or maybe a little more aggressive
You basically have 2 options-
1)Buy the LT4 extreme duty~$300
2)buy an electric water pump~$200 And you can use a SBC timing set~$100
I decided to go with option 2 on mine, It comes out pretty close money wise...but the electric pump will free up a few HP.
Originally posted by 96 WS6
A double roller won't clear the water pump unless you get an electric one. An LT4 extreme duty will go in with no modification.
You can't run a double roller timing set on a 94 without changing your cam to the one with the big hole in the center and longer dowel to the 95 and newer opti you will also need. The front cover on the motor (You know the one thats covers the timing chain & gears) also has to be changed to the 95 and newer model because it has more clearance on the inside. The Opti is driven with the longer dowel (no Spline). Believe me I tried to find a double roller set up for a 94Z for my 385, There isn't one.
